It is currently August 25th, 2026, 6:06 pm
PostPosted: March 22nd, 2016, 10:50 am
I have a Tek TDS 210 digital storage scope for sale. It also has a TDS2CM communications module installed. Before I list it on ebay I wanted to give someone here a shot at it. It is dual trace with a 60 MHz bandwidth, has lots of triggering options, and much more. Here is a link to a fact sheet:
http://www.tek.com/document/fact-sheet/ ... fact-sheet
Here is a link to the user manual:
http://mmrc.caltech.edu/Oscilliscope/TD ... Manual.pdf
The communications module allows capture of traces with Centronix, RS232, and GPIB output. The RS232 output has stopped working. Everything else works. It has the original documentation, power cord, and two TEK probes. $150 plus shipping if you can't pick it up.
