It is currently November 21st, 2026, 5:22 am
PostPosted: May 28th, 2020, 10:14 am
I want to pass on a TV chassis for DIY builder interested in making a tube amp. Here is what it has. Power transformer with copper shorting band (to reduce stray fields). Windings- 6.3V @7A; 6.3V @1.2A; 5V @3A; 320-0-320 V to rectify into 320 to 400 Vdc with full wave ct configuration @0.2A?. Also, filter choke around 2 H. Around 15 tubes, should be all good. Many terminal strips; many replaced capacitors. All point-to-point wiring as this predates circuit boards, probably vintage early 1950s. It can be powered up to play around, but I have removed the flyback transformer which was the cause of failure. I had operated the set periodically to keep the caps formed. I also have removed and discarded the picture tube.
Free for local pickup Potomac, MD
