| Needed: DDR laptop memory http://dcaudiodiy.com/phpBB3/viewtopic.php?f=7&t=1602 |
Page 1 of 1 |
| Author: | mix4fix [ April 4th, 2020, 7:43 pm ] |
| Post subject: | Needed: DDR laptop memory |
Anybody have any laptop DDR memory sitting around? |
| Author: | Pelliott321 [ April 5th, 2020, 7:16 am ] |
| Post subject: | Re: Needed: DDR laptop memory |
Sorry I just threw out some old 8mb pieces last week when cleaning out some junk |
| Author: | mix4fix [ April 5th, 2020, 11:40 am ] |
Need 1GB or 2GB DDR for an old Dell. Could use another hard drive as well. It has some type of IDE adapter piece that slides into the side of the laptop/motherboard. |
| Author: | Pelliott321 [ April 5th, 2020, 12:48 pm ] |
Threw out a 250gb laptop he when I upgraded to ssd |
| Author: | HAL [ April 5th, 2020, 3:44 pm ] |
mix4fix wrote: Need 1GB or 2GB DDR for an old Dell. Could use another hard drive as well. It has some type of IDE adapter piece that slides into the side of the laptop/motherboard. Might be a PCMCIA slot for external devices, like sound cards, USB connections, WiFi adapters and hard drives. There are different styles of DDR laptop memory SIMMs, so you need to know how many pins are on the SIMM that your machine needs. IIRC there is 208 pin and 200 pin styles for PC laptops. |
| Author: | SoundMods [ April 5th, 2020, 4:04 pm ] |
HAL wrote: mix4fix wrote: Need 1GB or 2GB DDR for an old Dell. Could use another hard drive as well. It has some type of IDE adapter piece that slides into the side of the laptop/motherboard. Might be a PCMCIA slot for external devices, like sound cards, USB connections, WiFi adapters and hard drives. There are different styles of DDR laptop memory SIMMs, so you need to know how many pins are on the SIMM that your machine needs. IIRC there is 208 pin and 200 pin styles for PC laptops. Or put another way -- the devil is the details. Not all memory modules are the same. He needs to not only identify exactly what his computer requires, but also how much RAM it will support. |
| Author: | mix4fix [ April 5th, 2020, 4:23 pm ] |
HAL wrote: mix4fix wrote: Need 1GB or 2GB DDR for an old Dell. Could use another hard drive as well. It has some type of IDE adapter piece that slides into the side of the laptop/motherboard. Might be a PCMCIA slot for external devices, like sound cards, USB connections, WiFi adapters and hard drives. There are different styles of DDR laptop memory SIMMs, so you need to know how many pins are on the SIMM that your machine needs. IIRC there is 208 pin and 200 pin styles for PC laptops. 1Gb 1024MB DDR SODIMM 333MHz PC2700 200pin 2.5v Max 2GB Hard drive connects with an adapter. It is keyed on a the hard drive side.
