| Hello from justinis http://dcaudiodiy.com/phpBB3/viewtopic.php?f=6&t=663 |
Page 1 of 2 |
| Author: | justinis [ July 15th, 2016, 10:11 am ] |
| Post subject: | Hello from justinis |
Hello, all! My name is Justin and I am an electrical engineer living in DC, working in Arlington. I love vintage and modern audio and visited the Capitol Audiofest 3 out of the last 4 years. This year I visited the DCAudioDIY room for the first time and found out about this forum. I'm so excited it exists and can't wait to jump in! Past projects: Restored Akai AP-207, Pioneer SA-6500, Marantz 1060, New Large Advent loudspeakers Current project: Building a 50W stereo power amp using a driver board for a Dynaco ST-70, tubes and transformers from a Heathkit AA-100 Future projects: Marantz 2226B restoration Current system: Pioneer SA-6500, New Large Advent loudspeakers, Technics SL-QD33 |
| Author: | FerdinandII [ July 15th, 2016, 10:47 am ] |
| Post subject: | Re: Hello from justinis |
Welcome Justinis, Those OPT transformers from the Heathkit AA-100 are excellent. Which driver board are you using? |
| Author: | justinis [ July 15th, 2016, 11:16 am ] |
Thanks! The DIYtube one by Shannon Parks. |
| Author: | FerdinandII [ July 15th, 2016, 11:53 am ] |
| Post subject: | B+ Voltage too high |
From another thread that disappeared...... ++++++++++++++++++++++++++++++++++++++ Are you measuring the voltage with a load on the power supply? With no load, the voltage will rise quite a bit. Try a 10k power resistor, or something in that range, so that you are pulling 50mA or so from the PSU. You'll need a big one.... See if the voltage drops down to the specified 445-450 VDC. Easy fixes are: Drop a 5R4 rectifier in there. or Change it from capacitor-input to choke input. Have you tried Duncan's PSU simulator? It's great for modeling the impact of component changes. |
| Author: | justinis [ July 15th, 2016, 1:33 pm ] |
Sorry, I deleted the thread cause I found an error in my calculations. Just put it back with new values: http://dcaudiodiy.com/phpBB3/viewtopic.php?f=4&t=665 Thanks for the tip! I do indeed have the powers supply loaded; the entire amp is built at this point. The 5R4 is a good suggestion, thanks. I was trying to avoid it cause I thought the zeners would be cheaper/easier, but now that it's screwing up my neg supply that's probably not true anymore. Don't understand the capacitor/choke vs choke input. Can you explain? Thanks! |
| Author: | FerdinandII [ July 15th, 2016, 4:27 pm ] |
justinis wrote: Sorry, I deleted the thread cause I found an error in my calculations. Just put it back with new values: http://dcaudiodiy.com/phpBB3/viewtopic.php?f=4&t=665 Don't understand the capacitor/choke vs choke input. Can you explain? Thanks! You put the choke first, directly downstream of the rectifier, then the filter caps. It can be Just an "L-C" filter network, or "L-C-L", or "L-C-L-C" (big C at the end). ![]() N.B. For low-level amplifier circuits, the choke input minimizes any high frequency artifacts generated by the rectifier. This is critical for any PSU that uses solid state rectifiers. |
| Author: | brombo [ July 15th, 2016, 4:42 pm ] |
If you are running linux (probably for windows also) there are free circuit analysis (simulation) tools available. Tubes can be modeled as linear (small signal transconductance model) or non-linear (non-linear voltage controlled current sources). There are also digital design and simulation tools and pcb design tools available. |
| Author: | brombo [ July 15th, 2016, 4:45 pm ] |
Here is link to tube models in SPICE circuit simulation code - http://www.normankoren.com/Audio/Tubemo ... ticle.html |
| Author: | FerdinandII [ July 15th, 2016, 4:51 pm ] |
Duncan's PSU Designer is the best, IMHO..... http://www.duncanamps.com/psud2/download.html |
| Author: | brombo [ July 15th, 2016, 5:21 pm ] |
I was thinking more of simulating the entire amplifier. |
