New Cartridge brake-in deadly
http://dcaudiodiy.com/phpBB3/viewtopic.php?f=5&t=954
Page 1 of 7
Author:  Pelliott321 [ December 30th, 2017, 12:51 pm ]
Post subject:  New Cartridge brake-in deadly
Breaking in a new cartridge since my prized Alpha Genesis 1000 died.
The suspension gave way and SoundSmith said it was unrepairable. So I decided to try the Denon103R.
I bought new off the Web for just over $300 and immediately tore the cover off and mounted into an aftermarket body.
so I am into the burn in just about 10 hrs. First 5 albums were deadly. I am now starting to hear some musicality, but it need to go much further if this is going to be a keeper
Author:  SoundMods [ December 30th, 2017, 2:14 pm ]
Post subject:  Re: New Cartridge brake-in deadly
I did a Denon 103D a long time ago. That after-market metal fitting you bought is probably your problem. Reuse the stock plastic fitting -- only when putting it back fill all the voids with RTV silicon being careful not to damage any wiring. Put it together caefully and wait 24-hours to give the RTV enough time to cure properly. You'll find the Denon will behave itself in a musical way. Tight with good midrange bloom. However, compared to the competition the Denon can be somewhat opaque.
Author:  TubeDriver [ December 30th, 2017, 3:04 pm ]
What arm are you using?
Author:  Pelliott321 [ January 1st, 2018, 11:47 am ]
Walt:
I did a lot of research and there are two preferred mods based a lot of Denon lovers out there. Both preferred mods are aluminum bodies. The one I picked also uses lead as an additional dampener as well as epoxy as a potting method.
Your opinion is only one of thousands
Author:  Pelliott321 [ January 1st, 2018, 11:54 am ]
Tonearm is Fern&Roby unipivot that Chris Hildebrand modified to fit on my Sota Nova
Author:  Pelliott321 [ January 1st, 2018, 12:12 pm ]
Aluminum body for Deno 103R
Author:  SoundMods [ January 1st, 2018, 12:37 pm ]
Walt:
And how is that working out for you?
Author:  Roscoe Primrose [ January 1st, 2018, 1:23 pm ]
Walt:
Oh, come on Walt, he read it on the Internet, so it HAS to be true. :sad-roulette:
Author:  SoundMods [ January 1st, 2018, 2:09 pm ]
Walt:
Rosco -- the more I get to know you -- the better I like you. :thumbup:
Author:  Pelliott321 [ January 1st, 2018, 2:25 pm ]
just saying everyone has an opinion, not necessarily right.
I started this in just stating that Cartridge brake-in is a pain. I only have 10 albums in, less than 7 hrs
I was not asking for any opinions of my choices, but some on this site just has to spew out declarations as if there is only one way
Page 1 of 7 All times are UTC - 5 hours [ DST ]
