Passive crossovers
Posted: October 27th, 2017, 5:57 pm
I moved this discussion to another thread. The test we did was double blind but did not use any device. Rather all the capacitors in the crossover were removed and replaced between trials. All the capacitors were measured so the values between the different types under test were the same. The test worked as follows. I downloaded a random sample test sequence from the web and printed it out so I knew which set, either a or b to use for each test. Listening was done first with both sets of caps where the listeners knew what the caps were. After they had a chance to listen to both where they knew what they were, we started the blind test.
This section of the test was done by asking all the listeners to go into another room. I then put in the capacitors from group a or b depending on the random selection sheet I had. I then left the room before the test started so I could not affect the test. When they were through with the listening and recorded their choices they left the room and I returned to put in whatever set of caps was called for on the random sheet. I then left the room again, the listeners returned and the next sequence of test began. This continued for the whole series of tests.
At the end, no one was able to determine beyond 50% certainty which capacitors were used for each test. That is as accurate as a flip of the coin and nowhere significant. This was not my first rodeo and the same results happened each time I was part of similar tests, either as a listener or running the test.
What this or any double blind test means is that for this group of subjects with this equipment and this music no one was able to determine a difference. Other situations may yield a different result. It is important to note that before the test the concensus was that there were huge differences in the caps that anyone could hear on any music but that proved not to be so. I'm sure this will in no way change the opinions of the die hards who insist on the overwhelming superiority of this or that component, but in all my years of audio, I have found that the biggest differences by huge amounts are in three areas, the recording and mastering over which you have no control other than to get other source material, your listening room, and the speakers, primarily the drivers, enclosures or lack thereof, and the proper design of crossovers, not necessarily the choice of "super" components, but rather components of good quality properly configured. And ofd course, a good passive crossover can be as good as a good active crossover, but is a pain in the behind and very expensive to produce. It also locks you in to a certain result unless you want to forever swap out components. Also, you cannot do those changes on the fly as you can with actives.
So this is another case of ya pays your money and ya takes your choice. It is a hobby and you need to do whatever floats your boat.
