It is currently April 24th, 2024, 9:00 pm
PostPosted: September 7th, 2017, 10:07 pm
STEP 00: Level TT
- Flat un-modulated LP w/ball-bearing
STEP 0: Validate iRIAA is accurate
- MLS with Hagtech iRIAA
- Channels match ?
STEP 1: Mount the cartridge in the head-shell
- Use "good" mounting hardware (stainless)
- Mount the cartridge loosely in the head-shell.
- Snug one side ( allow cartridge to pivot )
- Avoid torquing tonearm bearing.
STEP 2: Attach leads to cartridge pins
- Leave phono-cartridge cover in place
- Be careful - many cartridges are broken in this step
- Use tweezers or small needle-nose pliers
- Expand leads with toothpick if too small
STEP 3: Set VTF (vertical tracking force).
- Use MFR highest recommended value
- Use Shure to get to ballpark
- Finish with digital ( + Wally LP disk level tool)
STEP 4: Use geometry tool (Lofgren, baby)
- Verify P_to_S distance for arm is 100% accurate [ <0.01mm all is lost if not done]
- 1st Dennessen
- 2nd Feickert
- 3rd (Final) Wally
STEP 5: SRA
- Optional -- measure cartridge height and use Wally cartridge skid as starting point ( you are dismounting cartridge -- go back to STEP 1)
- Raise/lower rear of tonearm
- Use Dino-Lite digital microscope to measure SRA angle
- Aim for 91 degrees
STEP 6: Azimuth
- Mirror -- thickness of 180g LP
- Fosgate Fozgometer
- O'scope -- Test LP's 1Khz at different points
- Feickert Adjust+
STEP 7: Anti-Skate
- Flat un-modulated disc
- Wally AS tool
STEP 7: Tighten Screws
- Tighten just enough to allow playing
STEP 8: Listen to music
- Voice
- Bass
- Treble
- Stereo Separation
- Stereo Spread (Sound field)
- Imaging
STEP 8: Iterate over STEPS 3-8 until perfect
STEP 9: Tighten Screws
- Tighten with calibrated WIHA torque wrench (0.4 mn)
STEP 10: Wait for next Audio-club meeting where everybody tells you it is off/wrong
- Get the handgun and shoot them in the dick
Ralph Waldo Emerson
PostPosted: September 8th, 2017, 5:25 am
Love it, your hammer is dead center
Users browsing this forum: No registered users and 69 guests
