| Sheet Metal Cutter http://dcaudiodiy.com/phpBB3/viewtopic.php?f=5&t=849 |
Page 1 of 2 |
| Author: | SoundMods [ July 17th, 2017, 12:18 pm ] |
| Post subject: | Sheet Metal Cutter |
I caught an advertisement on television about the Versa Cutter and it appears that this gizmo can be the answer to easily cutting sheet metal. Previously I had to use tin snips. UGH! A Saber saw or band saw is just as bad and awkward to use. I ordered the Versa Cutter today and can't wait to get my hands on it. Here is the link: http://www.versicutter.com/ I did some "homework" and found that an Australian industrial company invented the device and holds a patent for it. They are licensing it out and one on TV is the same one the originator sells with a different color. Also, you get a nice set of accessories with it that cost extra "Down Under." BTW -- it's considered an alternative to a plasma cutter. COOL! |
| Author: | Pelliott321 [ July 17th, 2017, 12:25 pm ] |
| Post subject: | Re: Sheet Metal Cutter |
If it works like the video then it will be useful as a bench tool. Looks awkward as a hand tool. |
| Author: | brombo [ July 17th, 2017, 12:34 pm ] |
You might do better with this - https://www.amazon.com/Milwaukee-6852-2 ... B000EP499E than a cheap Chinese tool that will get dull quickly. I am wary of anything that is advertised on cable TV. |
| Author: | SoundMods [ July 17th, 2017, 12:36 pm ] |
Not Chinese. It is the exact same tool the inventors are selling with hardened bits. |
| Author: | FerdinandII [ July 17th, 2017, 12:50 pm ] |
This tool is similar to what I used to call a nibbler. It has a lot of advantages compared to a shear-type device, especially when working in tight confines. |
| Author: | DaveR [ July 17th, 2017, 12:51 pm ] |
brombo wrote: You might do better with this - https://www.amazon.com/Milwaukee-6852-2 ... B000EP499E than a cheap Chinese tool that will get dull quickly. I am wary of anything that is advertised on cable TV. I have one of these, it works great. |
| Author: | SoundMods [ July 17th, 2017, 1:29 pm ] |
YUP! It is a nibbler! |
| Author: | tomp [ July 17th, 2017, 3:10 pm ] |
I have been using this nibbler for over 50 years and it works great. Slower than motorized but unless you have production work it is not a problem and much easier to use especially in tight places than a tool you connect to a drill. http://www.aircraftspruce.com/catalog/t ... ngtool.php |
| Author: | SoundMods [ July 17th, 2017, 4:00 pm ] |
My hand aches just thinking about using a manual nibbler. OUCH! |
| Author: | tomp [ July 17th, 2017, 4:33 pm ] |
SoundMods wrote: My hand aches just thinking about using a manual nibbler. OUCH! Wimp! |
