| Location of components? Does order count? http://dcaudiodiy.com/phpBB3/viewtopic.php?f=5&t=752 |
Page 1 of 1 |
| Author: | TubeDriver [ November 16th, 2016, 3:23 pm ] |
| Post subject: | Location of components? Does order count? |
So I have a DAC>2' interconnect>autoformer preamp>10' interconnect> amps Could it sound different if I went DAC>10' interconnect>preamp>2' interconnect> amps? Assume the DAC has a robust output stage (is designed to drive interconnects and amp), amps have 100K input impedance. I know I can try to see if I hear any change but conceptually should it matter? I sort of see it as A+B = C and B+A = C in that the sum of the component variables remains unchanged? |
| Author: | Roscoe Primrose [ November 16th, 2016, 3:26 pm ] |
| Post subject: | Re: Location of components? Does order count? |
With an autoformer volume control, probably not much difference. If you were running a resistive volume control, you'd probably be better off with the shorter interconnects after the volume control... Roscoe |
