| 6 ohm speakers on 4 / 8 ohm taps? http://dcaudiodiy.com/phpBB3/viewtopic.php?f=5&t=734 |
Page 1 of 1 |
| Author: | justinis [ October 18th, 2016, 11:15 am ] |
| Post subject: | 6 ohm speakers on 4 / 8 ohm taps? |
I have a tube amplifier with 4 and 8 ohm taps. I'm considering some 6 ohm speakers but I have some questions: 1. Which tap should I use? I assume the 4 ohm tap will cause less distortion because it will load the transformers less? But I will need more power to achieve the same level of volume? 2. Will speaker efficiency rating be affected? Thanks for your advice! |
| Author: | Roscoe Primrose [ October 18th, 2016, 11:19 am ] |
| Post subject: | Re: 6 ohm speakers on 4 / 8 ohm taps? |
They'll both work fine. It's gonna be a case by case basis for any given amp/speaker pairing as to which one sounds better, that's why you have ears Roscoe |
| Author: | justinis [ October 18th, 2016, 12:52 pm ] |
I knew these things would come in handy! |
| Author: | TubeDriver [ October 18th, 2016, 1:14 pm ] |
You can give safely give both taps a shot but in general you might have best luck using the taps that the transformer designer intended. You might get reduced distortion by using the 4 ohm taps with 8 ohm speaker but at the cost of chopping off half of the transformers inductance. |
| Author: | justinis [ October 18th, 2016, 1:20 pm ] |
Crap, I just realized I put "8 ohm" in my original post when I meant "6 ohm!" I will change it so this question actually makes sense. Sorry! |
| Author: | Roscoe Primrose [ October 18th, 2016, 1:26 pm ] |
Yeah, I noticed, but I assumed it was a typo since you put 6 ohms in the thread title... Roscoe |
