PostPosted: October 18th, 2016, 11:15 am
I have a tube amplifier with 4 and 8 ohm taps. I'm considering some 6 ohm speakers but I have some questions:
1. Which tap should I use? I assume the 4 ohm tap will cause less distortion because it will load the transformers less? But I will need more power to achieve the same level of volume?
2. Will speaker efficiency rating be affected?
Thanks for your advice!
PostPosted: October 18th, 2016, 11:19 am
They'll both work fine. It's gonna be a case by case basis for any given amp/speaker pairing as to which one sounds better, that's why you have ears ;)
PostPosted: October 18th, 2016, 12:52 pm
I knew these things would come in handy!
PostPosted: October 18th, 2016, 1:14 pm
You can give safely give both taps a shot but in general you might have best luck using the taps that the transformer designer intended.
You might get reduced distortion by using the 4 ohm taps with 8 ohm speaker but at the cost of chopping off half of the transformers inductance.
PostPosted: October 18th, 2016, 1:20 pm
Crap, I just realized I put "8 ohm" in my original post when I meant "6 ohm!" I will change it so this question actually makes sense. Sorry!
PostPosted: October 18th, 2016, 1:26 pm
Yeah, I noticed, but I assumed it was a typo since you put 6 ohms in the thread title... ;)
