It is currently April 25th, 2024, 2:51 am
PostPosted: January 5th, 2016, 1:01 pm
Lacquer thinner typically is acetone. Acetone will "eat plastics for lunch" and without knowing what dielectric materials (especially polystyrene) were used in the manufacture of the heads you can possibly ruin the heads permanently. :(
Soaking the rubber parts in water/detergent solution is not advisable as some rubbers (natural and synthetic) are hydroscopic meaning they may absorb the solution. There is no way to predict what harm that can cause.
What we are cleaning off of tape recorder parts is nothing more than the shed magnetic oxide. I found that cleaning the capstan and pinch rollers an easy routine task with mineral spirits. No harm was ever done and the equipment worked fine. Many recordings later (including three LPs) and my machines worked as new. One was a TEAC and my main machine was a Studer. I also used these methods on a Tandberg machine in a small audio system.
Tape recorders are rare, what with affordable digital recording devices available now, and finding NOS parts, or even someone to work on them, is getting more and more difficult.
PostPosted: January 5th, 2016, 1:04 pm
I have done a number of restorations of various reel-to-reel machines, and am also on the ampex listserv. IIRC, almost everyone one of these top professional machine operators (and I mean top pros) use IPA for cleaning heads and most pinch rollers. If your rollers have gotten hard, you can send them to Terry DeWick for a rebuild, he is tops in that area. Lubrication is a different animal, but I believe Rabbi Rich uses with lithium grease, I would have to look that up. You may also want to check on tapeheads.com to see what the members there recommend. If you are looking for the best restorer of tape machines, that would be Tim Leinbaugh at Music Technology in Springfield, VA. I worked with Tim there several years back, he has been doing repairs and restos for decades.
PostPosted: January 5th, 2016, 1:18 pm
As noted, the lacquer thinner was recommended by my tape tech. I've used it for years without problems. The soap-and-water regimen for pinch rollers was recommended by Terry Witt, of Terry's Rubber Rollers, who has probably re-rubbered more pinch rollers than anyone in history. 'Course he may simply be trying to increase future business, but I kinda doubt it.
I use my tape decks (Otari and Teac) daily and have a vested interest in keeping them in good shape.
Dave P.
EDIT Some follow-up. Forgot to mention that after the pinch rollers have been steeped in their Dawn bath, I scrub the surfaces with a toothbrush. You can tell just how anal I am about all this tape stuff by the fact that I have 3 pinch rollers for the Otari (and 4 headstacks) and 2 for the Teac (which has new heads), plus a Han-D-Mag tape head demagnetizer and a couple Annis magnetometers to help tell me when it's time to use the Han-D-Mag. I've been at this a L-O-N-G time.
PostPosted: January 5th, 2016, 1:45 pm
As Walt noted, I would be very careful about using any lacquer thinner or the like on any tape heads. I believe it is not recommended, there are tape heads, such as the glass ferrite heads used by Akai and others (?) that lacquer thinner will loosen the lams, IPA seems to be the universal cleaner for tape heads, FWIW
PostPosted: January 5th, 2016, 2:09 pm
I have found a good light oil is TS-619 sewing machine oil. It is a synthetic designed for commercial sewing machines that have heavy demands on their spindles. I use it straight and also doped with tungsten disulfide powder in extreme uses like firearms. Here is a link:
https://www.tsmoly.com/catalog/product_ ... cts_id=231
Users browsing this forum: No registered users and 58 guests
