It is currently November 13th, 2026, 5:28 am
PostPosted: September 30th, 2015, 6:47 pm
I'm using the Angela Universal poer transformers. The HV secondaries are 380-320-0-320-380. Is there any reason I couldn't use bothe sets of secondaries with the same center tap, as long as I don't exceed the rating of the transformer? For instance, the higher voltage pair for the input stage (20ma) and the lower-voltage pair for the output stage?
PostPosted: September 30th, 2015, 7:14 pm
Shouldn't be a problem.... Not any different than using a bias tap....
PostPosted: September 30th, 2015, 8:03 pm
That's what I figured. Thanks!
