| DIY amps http://dcaudiodiy.com/phpBB3/viewtopic.php?f=5&t=474 |
Page 1 of 1 |
| Author: | JDCrae [ July 16th, 2014, 9:08 pm ] |
| Post subject: | DIY amps |
Does anyone have any experience with eBay amps ? I've seen some kits requiring soldering and caps that can be had for 65.00 and allegedly put out 100 wpc. Too good to be true ? Have seen some DIY tube amps too but the power output seems very very low. Open to all thoughts and insights. Jeff |
| Author: | cport [ July 16th, 2014, 10:59 pm ] |
| Post subject: | Re: DIY amps |
Hi Jeff: These >LM3886< amps are legit (this photo won't last long, or the link above ... ...) 2x ~50watts for ~$40.00 (plus $30.00 for trafo) |
| Author: | JDCrae [ July 17th, 2014, 6:01 pm ] |
If I were to go this route - using this board as the example, what else would be needed to make it a functional amp? Anything cheap that would be best to upgrade? These remind me of that radio shack radio kit I put together as a kid. Problem is mine never worked lol cport wrote: Hi Jeff:
| Author: | cport [ July 17th, 2014, 6:58 pm ] |
You would need the following (assuming four channels -- 2x KITS): 1.) 2x transformers 220VA-330VA with dual secondaries producing between 18VAC and 25VAC 2.) 2x Power cords 3.) Chassis with Ground (if w/kids) or "whatever" if not 4.) Hookup wire 5.) Speaker wire (if you don't have any) 6.) RCA phono connectors 7.) Solder "barrier-strip" or phenolic terminal pad ( AC mains to trafo) 8.) AL Heat sinks w/ heat sink grease. (a perforated AL 'slab' serves) These are prebuilt and tested -- you have no soldering to do on the boards -- just hookup. Or you could break down and get one of these -- UPA-500 \\Charles |
