Ethernet Cabling for Audio Streaming
http://dcaudiodiy.com/phpBB3/viewtopic.php?f=5&t=3233
Page 1 of 1
Author:  Cogito [ October 8th, 2026, 8:50 pm ]
Post subject:  Ethernet Cabling for Audio Streaming
Recently, I had an interaction with the HQPlayer developer about using a network isolator in front of a Holo Red NAA to reduce network noise. I loved his response—simple, effective, and almost free.
Don’t use shielded Ethernet cables. The shield connects the grounds and bypasses the built-in galvanic isolation.
Instead, use CAT6A U/UTP (unshielded twisted pair) cables with fully plastic connectors. This preserves the galvanic isolation already built into Ethernet.
Sometimes the simplest solution is the best one.
