It is currently November 13th, 2026, 4:36 am
PostPosted: October 8th, 2026, 8:50 pm
Recently, I had an interaction with the HQPlayer developer about using a network isolator in front of a Holo Red NAA to reduce network noise. I loved his response—simple, effective, and almost free.
Don’t use shielded Ethernet cables. The shield connects the grounds and bypasses the built-in galvanic isolation.
Instead, use CAT6A U/UTP (unshielded twisted pair) cables with fully plastic connectors. This preserves the galvanic isolation already built into Ethernet.
Sometimes the simplest solution is the best one.
Users browsing this forum: Baidu [Spider] and 26 guests
