It is currently November 4th, 2026, 12:31 am
 Post subject: Daphile
PostPosted: September 2nd, 2024, 7:53 pm
Online
Are you able to format a secondary drive (either directly in Daphile, or remotely)?
 Post subject: Re: Daphile
PostPosted: September 2nd, 2024, 10:31 pm
No. Daphile does not have the low level functionality to create partitions and format drives. You can boot with a GParted USB stick that allow you to partition and format drives, but you need to know what you are doing since you can screw up your system/storage disc if you are not careful.
PostPosted: September 10th, 2024, 12:53 am
Online
Any trick to transfer audio files between computers and daphile?
PostPosted: September 10th, 2024, 1:58 am
The local storage on a daphile box can be setup as a network share...
PostPosted: September 10th, 2024, 1:18 pm
Online
Is there a setting I am missing?
Drives are "share" and "rw".
PostPosted: September 22nd, 2024, 12:25 am
Online
I re-installed Daphile. I tried all three ISO versions. But, for some reason, Daphile doesn't open the left side settings to save the configuration. I tried different browsers as well. Daphile has worked on this computer before.
Any thoughts?
Users browsing this forum: Baidu [Spider] and 138 guests
