| Daphile http://dcaudiodiy.com/phpBB3/viewtopic.php?f=5&t=2376 |
Page 1 of 1 |
| Author: | mix4fix [ September 2nd, 2024, 7:53 pm ] |
| Post subject: | Daphile |
Are you able to format a secondary drive (either directly in Daphile, or remotely)? |
| Author: | David McGown [ September 2nd, 2024, 10:31 pm ] |
| Post subject: | Re: Daphile |
No. Daphile does not have the low level functionality to create partitions and format drives. You can boot with a GParted USB stick that allow you to partition and format drives, but you need to know what you are doing since you can screw up your system/storage disc if you are not careful. David |
| Author: | mix4fix [ September 10th, 2024, 12:53 am ] |
Any trick to transfer audio files between computers and daphile? |
| Author: | Roscoe Primrose [ September 10th, 2024, 1:58 am ] |
The local storage on a daphile box can be setup as a network share... Roscoe |
| Author: | mix4fix [ September 10th, 2024, 1:18 pm ] |
Is there a setting I am missing? Drives are "share" and "rw". |
| Author: | mix4fix [ September 22nd, 2024, 12:25 am ] |
I re-installed Daphile. I tried all three ISO versions. But, for some reason, Daphile doesn't open the left side settings to save the configuration. I tried different browsers as well. Daphile has worked on this computer before. Any thoughts? |
