Triax Speaker Cables
http://dcaudiodiy.com/phpBB3/viewtopic.php?f=5&t=2247
Page 1 of 1
Author:  brombo [ July 12th, 2023, 11:41 am ]
Post subject:  Triax Speaker Cables
Has anyone tried triaxial cable for speaker wires where you forget about the center conductor and use the two insulated braids for the + and - connections. The reason I am asking is in a active speaker system (separate amplifier for each driver) you want to minimize cross talk (coupling) between the cables for each of the drivers.
Author:  SoundMods [ July 12th, 2023, 1:23 pm ]
Post subject:  Re: Triax Speaker Cables
I haven't, but I have had amazing success with Andrew Heliax. The Heliax steps out of the way -- doesn't editorialize -- transparency to the audio signal is an understatement -- and it is very musical.
Andrew_Heliax_Plenum_Rated_CATVP.pdf [32.22 KiB]
Downloaded 1193 times
Author:  brombo [ July 12th, 2023, 1:45 pm ]
Back in the late 60's and early 70's I was on three underground nuclear tests in Nevada. After each test thousands of feet of the heliax cable were trashed (it was still good and not radioactive).
Author:  SoundMods [ July 12th, 2023, 11:25 pm ]
That would have been an amazing freebie!
Author:  Jkdahlman [ July 12th, 2023, 11:41 pm ]
I've been using Sommer SC-Magellan coax speaker cable in the studio lately. It's a great sounding cable and easy to work with. Disclaimer : I use a lot of Sommer cable in my proaudio business, so I'm a bit biased.
John crawling back into the studio...
https://shop.sommercable.com/en/Cable/B ... escription
Author:  brombo [ July 13th, 2023, 9:26 am ]
This is more easily available so I will use it -
https://mogamicable.com/category/bulk/s ... ure_sound/
Again my major concern for 4-way stereo speakers is coupling between the cables for the drivers especially if I try to make the cabling neat by taping the cables together. Using coaxial cables should eliminate any coupling. Note that you can even have coupling in a cable with four twisted pairs such as Belden makes.
Author:  SoundMods [ July 14th, 2023, 11:07 am ]
The issue with Mogami cable is the dielectric -- PVC. Not recommended. Then there is the fact that it is stranded. I found that stranded speaker cable muddies the mid-range and treble with a tendency to be "grainy."
Author:  Pelliott321 [ July 14th, 2023, 11:34 am ]
I have a friend that has been in the business for over 30 years and produces highly regarded audio that says never give the signal multiple paths.
Author:  brombo [ July 14th, 2023, 11:43 am ]
My comments only apply to active speaker systems where you have a separate cable feeding each driver. They do not apply to a system with a single cable feeding a passive crossover.
