| Speaker Snap http://dcaudiodiy.com/phpBB3/viewtopic.php?f=5&t=2231 |
Page 1 of 1 |
| Author: | mix4fix [ April 22nd, 2023, 3:39 pm ] |
| Post subject: | Speaker Snap |
https://www.speakersnap.com/ Quote: The Fastest Banana Plugs Money Can Buy
| Author: | Grover Gardner [ April 22nd, 2023, 11:36 pm ] |
| Post subject: | Re: Speaker Snap |
mix4fix wrote: https://www.speakersnap.com/ Quote: The Fastest Banana Plugs Money Can Buy Cool! Thank you! I need those! |
| Author: | mix4fix [ April 23rd, 2023, 4:20 pm ] |
Is it me, or does the ones with the screws look less cheap? |
| Author: | FerdinandII [ April 23rd, 2023, 8:05 pm ] |
WRT Audio connections, low mass is usually better, even if they look cheap. Sudden changes in "sectional density" can cause issues. For speaker connections, these tube connectors are a good example of a smooth transition from one piece of wire to the next. mix4fix wrote: Is it me, or does the ones with the screws look less cheap?
| Author: | FerdinandII [ April 23rd, 2023, 8:20 pm ] |
These "Wago-style" connectors have taken over the junction box wiring market. https://www.wago.com/us/discover-wire-and-splicing-connectors/221 https://ideadigitalasset.com/DAMRoot/Original/10069/11008_ID-SPE-v1-SNAP5362WA.pdf I won't comment on whether they are any good for that application, as I am not qualified. In general though, most innovations designed to make a professional's job easier, faster, and more foolproof will increase the number of ways that an amateur can screw it up. mix4fix wrote: Is it me, or does the ones with the screws look less cheap?
| Author: | SoundMods [ April 23rd, 2023, 10:01 pm ] |
As far as I am concerned the following link will take you to just about best banana plugs money can buy. They are aggressive for a tight fit and can be soldered. https://www.ebay.com/itm/373874884522?h ... BMoJXej_Zh |
