Page 1 of 2
Daphile not recogniziing external CD Drive after update.
Posted: January 23rd, 2023, 1:15 am
by mix4fix
After a firmware update, the external CD drive doesn't work. Any ideas?
Re: Daphile not recogniziing external CD Drive after update.
Posted: January 24th, 2023, 6:56 pm
by mix4fix
Also, the radio part has no sound but listening to my tracks works fine.
Posted: February 15th, 2023, 6:05 am
by mix4fix
External CD drive works now.
Need help getting any DAC to work.
Posted: February 15th, 2023, 8:49 pm
by Roscoe Primrose
mix4fix wrote:External CD drive works now.
You should be able to choose your DAC in the dropdown box in the lower right corner...
Posted: February 16th, 2023, 3:57 am
by mix4fix
Roscoe Primrose wrote:mix4fix wrote:External CD drive works now.
Drive is on and off working. I start up, it doesn't work. I go to settings and save/restart and sometimes it will work.
The old Pop/Pulse DAC shows up but doesn't play. The Leaf DAC doesn't show up.
Posted: February 17th, 2023, 2:29 am
by mix4fix
I got the Pop/Pulse to work, but it sounded distorted. The line out jack plays from the PC.
Posted: February 17th, 2023, 5:37 pm
by mix4fix
mix4fix wrote:I got the Pop/Pulse to work, but it sounded distorted. The line out jack plays from the PC.
No DAC seems to work. If I stream something, it plays OK on the PC's audio out but it regularly cuts out then returns.
Posted: February 17th, 2023, 6:46 pm
by Roscoe Primrose
What are you using for a PC?
Posted: February 17th, 2023, 9:55 pm
by mix4fix
Posted: February 18th, 2023, 12:13 am
by Roscoe Primrose
That's pushing the lower limits on hardware. I had problems with a somewhat faster Celeron 1037 U...
