It is currently October 31st, 2026, 1:42 pm
PostPosted: January 23rd, 2023, 1:15 am
After a firmware update, the external CD drive doesn't work. Any ideas?
PostPosted: January 24th, 2023, 6:56 pm
Also, the radio part has no sound but listening to my tracks works fine.
PostPosted: February 15th, 2023, 6:05 am
External CD drive works now.
Need help getting any DAC to work.
PostPosted: February 15th, 2023, 8:49 pm
You should be able to choose your DAC in the dropdown box in the lower right corner...
PostPosted: February 16th, 2023, 3:57 am
Drive is on and off working. I start up, it doesn't work. I go to settings and save/restart and sometimes it will work.
The old Pop/Pulse DAC shows up but doesn't play. The Leaf DAC doesn't show up.
PostPosted: February 17th, 2023, 2:29 am
I got the Pop/Pulse to work, but it sounded distorted. The line out jack plays from the PC.
PostPosted: February 17th, 2023, 5:37 pm
No DAC seems to work. If I stream something, it plays OK on the PC's audio out but it regularly cuts out then returns.
PostPosted: February 17th, 2023, 6:46 pm
What are you using for a PC? :confusion-confused:
PostPosted: February 17th, 2023, 9:55 pm
https://www.asrock.com/MB/Intel/D1800B-ITX/index.asp
PostPosted: February 18th, 2023, 12:13 am
That's pushing the lower limits on hardware. I had problems with a somewhat faster Celeron 1037 U...
