It is currently April 17th, 2024, 10:26 pm
PostPosted: October 30th, 2022, 10:43 am
Here is a lady that scratch builds tubes.
Actually she is building a 1920's designed tube amp but makes the tubes first.
This is real DIY
https://youtu.be/-UEfqAWb3fE
PostPosted: October 30th, 2022, 1:52 pm
This is real DIY
This chick has taken DIY to an entirely different level!!!! WOW!! :o
PostPosted: October 30th, 2022, 3:11 pm
In order to do this there are three things you need:
1. Glass blowing ability (don't inhale)
2. A good vacuum system
3. A knowledge of Cathode chemistry both for directly and indirectly heated cathodes.
The killer is number 2. The National Capital Astronomer's Telescope Making Class at the Chevy Chase Community Center has a vacuum system that is good enough to Aluminize telescope mirrors. I don't know if that is good enough to evacuate tubes. You would need a system with a roughing pump, a diffusion pump, and a cold trap. I do know someone who could answer questions about cathode structures and chemistry if you couldn't find the answers online.
PostPosted: October 30th, 2022, 3:17 pm
This should also be of interest -
https://hackaday.com/2018/12/31/the-art ... brication/
PostPosted: October 30th, 2022, 4:40 pm
When making high power electronic flash tubes, we used liquid nitrogen on the cold trap.
PostPosted: October 30th, 2022, 5:08 pm
Back in the 30's and 40's dry ice and I think acetone was what was used. Liquid Nitrogen is probably safer and better. For indirectly heated cathodes I think high purity Mike of Magnesia is used.
PostPosted: October 30th, 2022, 6:00 pm
Who is Mike Magnesia? :lol:
PostPosted: October 30th, 2022, 6:21 pm
I can't spell. Milk of Magnesia.
PostPosted: October 31st, 2022, 4:03 pm
More details -
