It is currently November 13th, 2026, 4:28 am
PostPosted: August 30th, 2021, 1:01 pm
If any of you are members of the Audio Engineering Society, there is a webinar coming up to discuss the new standards for transmitting audio over twisted pair. Here is a link:
https://aesstandardsaes72.aesshow.com/
PostPosted: August 30th, 2021, 1:15 pm
If only. AES/EBU, Ethernet, USB, and HDMI are different and similar in that no two designs are alike. So -- I have to ask -- what standards? Manufactured products are all over the place and the same goes for the electronics (sources and receivers).
Even with S/PDIF 75-ohm -- manufacturers do it in RCA and 50-ohm BNC connections and "call it" 75-ohm. WTF?!
PostPosted: August 30th, 2021, 1:20 pm
Sounds like a pure academic exercise.
Any new transport medium for digital audio should be better than USB and I2S, not the other way around.
Can you post the abstract?
PostPosted: August 30th, 2021, 3:19 pm
The AES has standards. And as you know everyone rigidly adheres to standards. :crazy:
PostPosted: August 30th, 2021, 3:21 pm
The webinar has not yet occurred. I don't believe this will be a discussion of the protocols, but rather the transport mechanism.
