New dynamic driver design and patent
http://dcaudiodiy.com/phpBB3/viewtopic.php?f=5&t=2017
Page 1 of 2
Author:  tomp [ June 10th, 2021, 1:55 pm ]
Post subject:  New dynamic driver design and patent
It is not often that a new type of dynamic driver is introduced. This is one of those cases.
http://www.dinaburgtech.com/technical.html
Author:  Roscoe Primrose [ June 10th, 2021, 2:19 pm ]
Post subject:  Re: New dynamic driver design and patent
Unless I'm missing something, it's a driver & a passive radiator on the same basket. I've never heard a system with a passive radiator that did bass well, so I'm a bit skeptical...
Author:  DaveR [ June 10th, 2021, 2:25 pm ]
Interesting. It's not a passive radiator, at least not in the conventional sense. I suppose the big question is how does it sound?
Author:  Roscoe Primrose [ June 10th, 2021, 2:27 pm ]
How so?
Author:  David McGown [ June 10th, 2021, 2:42 pm ]
Concur with Roscoe, it is an annular passive radiator. If you design the system right, it will work to extend the response of the midrange driver, since it is a free resonant system that can be tuned via mass, stiffness of the air spring of the enclosure, and the damping. IF the "Q" is such that you get a broad resonant response, then it could work pretty well relative to the midrange.
Author:  DaveR [ June 10th, 2021, 2:51 pm ]
How so?
I've never seen a passive radiator that was physically connected to the driven cone. I will admit I have not seen everything, so that may be where my confusion lies.
Author:  David McGown [ June 10th, 2021, 3:03 pm ]
It is not physically connected, the inner surround is coupled to same hardpoint on the driver frame as outer surround of the midrange.
Author:  Roscoe Primrose [ June 10th, 2021, 3:24 pm ]
Exactly. Otherwise, it'd be old technology, used in the Altec Biflex speakers, and others....
Author:  SoundMods [ June 10th, 2021, 3:38 pm ]
The U.S. Patent office will probably patent anything if you follow the application rules that date back to the 19th century.
I recall Electro-Voice offering similar drivers as well as Jensen. This appears to be an old "pig" with a "fresh coat of lipstick."
If the patent office does not do their homework (due diligence) then this guy may get his patent -- but I believe it is a long shot because of the many first-use examples out there.
Now it is possible they can prove that their device is an improvement over previous patents (if they exist) and get a new patent. Pharmaceutical companies use this stategy to keep their drugs in the game denying generics the chance to usurp their high prices.
Here are modern versions:
subwoofer-mid-range-speaker-coaxial-tweeter-mid-bass-midrange-speaker.jpg [ 82.51 KiB | Viewed 31740 times ]
Author:  DaveR [ June 10th, 2021, 3:42 pm ]
Ah, I get it now. Thanks.
