| Higher USB power http://dcaudiodiy.com/phpBB3/viewtopic.php?f=5&t=2012 |
Page 1 of 2 |
| Author: | tomp [ June 1st, 2021, 1:51 pm ] |
| Post subject: | Higher USB power |
A new specification has been proposed to allow up to 240W of power availability on a USB C connector. https://audioxpress.com/news/usb-specif ... usb-type-c Tom |
| Author: | Pelliott321 [ June 1st, 2021, 2:08 pm ] |
| Post subject: | Re: Higher USB power |
Hard to believe the USB type C connector can handle that much power |
| Author: | Roscoe Primrose [ June 1st, 2021, 2:12 pm ] |
Pelliott321 wrote: Hard to believe the USB type C connector can handle that much power Power isn't the issue, current is. That 240W is 5A at 48V.... Roscoe |
| Author: | David McGown [ June 1st, 2021, 2:16 pm ] |
Need to beef up the wire gauge to handle the current. 240W at 48V/5A is alot to push down thin wire for a typical USB Type C cable. Safe current for 24 ga. copper is around 3.5A, would need to go to at least 22 ga. wire. David |
| Author: | Pelliott321 [ June 1st, 2021, 2:17 pm ] |
potato potadoe |
| Author: | tomp [ June 1st, 2021, 2:54 pm ] |
It's amazing that the new spec is 10 times the original USB. Before you know it they will probably come with a whole house generator attached. |
| Author: | Roscoe Primrose [ June 1st, 2021, 3:03 pm ] |
Pelliott321 wrote: potato potadoe How do you figure? |
| Author: | HAL [ June 1st, 2021, 4:34 pm ] |
Yes, using the new GaN SMPS USBC 45watt supply and the cable is rated for 100 watts. That is 20V@5A, but the current does not go up at lower voltages. Probably due to connector pins in the USBC plug/jack more than wire diameter. |
| Author: | DaveR [ June 1st, 2021, 7:35 pm ] |
tomp wrote: A new specification has been proposed to allow up to 240W of power availability on a USB C connector. https://audioxpress.com/news/usb-specif ... usb-type-c Tom Why? |
| Author: | tomp [ June 1st, 2021, 8:34 pm ] |
Apparently a lot of people are making USB add ons that are power pigs. |
