It is currently June 30th, 2025, 4:50 pm
 Post subject: Re: What a fine day
PostPosted: August 17th, 2020, 6:59 am
Not familiar with technique
How do you do that
PostPosted: August 17th, 2020, 9:46 am
How do you do that
Others can explain it better than I can...
https://patdavid.net/2013/01/focus-stac ... nfuse.html
https://www.cambridgeincolour.com/tutor ... acking.htm
https://web.archive.org/web/20160917212 ... macro.html
PostPosted: August 17th, 2020, 10:55 am
looks interesting
I must give it a try
This would be much better than using unsharp F32 to gain max DOF
PostPosted: August 17th, 2020, 11:11 am
Absolutely. Of course, it's not much use for moving subjects... The Z6 has some capability to automate the process, but I haven't tried that yet. Did the one image I've done so far with the D750, and it doesn't have that capability. Once you've done it the first time, it's not that complicated. I think recent versions of photoshop can do it as well, but since I'm on Linux, PS isn't an option here ;) You can do the same thing with exposure with the same tools, think bright sunset over dark foreground....
PostPosted: August 17th, 2020, 11:18 am
It looks like there are scripts available to do this in PhotoShop Elements 2020
I may go that route first it may be simpler.
Users browsing this forum: Google [Bot] and 32 guests
