| Power Supply question http://dcaudiodiy.com/phpBB3/viewtopic.php?f=5&t=1656 |
Page 1 of 1 |
| Author: | Pelliott321 [ June 7th, 2020, 8:09 am ] |
| Post subject: | Power Supply question |
Let’s say you start off with a pi network cap-inductor-cap. I understand if you drop the first cap you have a choke loaded ps but to get the same voltage out as with the pi network you have to increase the volts in. Why? |
| Author: | GaryB [ June 7th, 2020, 9:22 am ] |
| Post subject: | Re: Power Supply question |
Capacitors try to maintain a constant voltage. That means that a large enough capacitor will charge up to the peak of the transformer output, which is ~1.414 x transformer secondary voltage. Inductors try to maintain a constant current. That means that a large enough inductor will cause the subsequent capacitors to charge to the average of the AC sine wave voltage, which is ~0.9 x transformer secondary voltage. |
| Author: | Pelliott321 [ June 7th, 2020, 10:32 am ] |
wow that was simple thanks |
