It is currently September 29th, 2026, 4:55 am
 Post subject: Power Supply question
PostPosted: June 7th, 2020, 8:09 am
Let’s say you start off with a pi network cap-inductor-cap. I understand if you drop the first cap you have a choke loaded ps but to get the same voltage out as with the pi network you have to increase the volts in.
Why?
PostPosted: June 7th, 2020, 9:22 am
Capacitors try to maintain a constant voltage. That means that a large enough capacitor will charge up to the peak of the transformer output, which is ~1.414 x transformer secondary voltage.
Inductors try to maintain a constant current. That means that a large enough inductor will cause the subsequent capacitors to charge to the average of the AC sine wave voltage, which is ~0.9 x transformer secondary voltage.
PostPosted: June 7th, 2020, 10:32 am
wow that was simple
thanks
Users browsing this forum: No registered users and 183 guests
