| Battery power for Elk Neck http://dcaudiodiy.com/phpBB3/viewtopic.php?f=5&t=1624 |
Page 1 of 2 |
| Author: | SoundMods [ May 13th, 2020, 10:58 am ] |
| Post subject: | Re: Battery power for Elk Neck |
Here is the thing -- a lot depends on the connected load to the UPS system and how long it will be viable during an outage. Lithium batteries are sneaky -- they have a flat performance curve then drop out when exhausted -- no droop -- just drop. Short-term outages could be served by a UPS system, but for long-term outages an emergency-power generator would be a better idea. But questions remain -- how short? -- how long? If it were me, my response would be: "Thanks but no thanks." I would rather install an Otto-Cycle emergency power generator that runs on either natural gas (if available) or LP gas and connected to "mission critical" loads like HVAC, lighting, and refrigeration. The typical automatic transfer switch (ATS) will start the generator within a minute with a run-time as long as the fuel-supply holds up. Most generator manufacturers can quote fuel consumption ratings to enable an informed decision. |
| Author: | ratbagp [ May 13th, 2020, 11:21 am ] |
If a tree falls, the outage is typically three to four hours. In major events where multiple trees fall such as snow / ice storms or small tornadoes, it can be several days before power is restored. Many houses in the community have emergency power generators already. I don't because I am a stubborn fool and I enjoy having candles for a change. ray |
| Author: | pboser [ May 13th, 2020, 11:31 am ] |
Looks like a beautiful place to live - even with candles. |
| Author: | Roscoe Primrose [ May 13th, 2020, 1:26 pm ] |
SoundMods wrote: The typical automatic transfer switch (ATS) will start the generator within a minute with a run-time as long as the fuel-supply holds up. When I worked at the data center, utility outage to generators carrying the full load in the building was about 4sec. All the critical loads were on UPS power as well.... We had more than 2wks worth of diesel on-site as well. Of course, that particular facility was more robustly built out in terms of generators, when the building was built there wasn't enough utility power available, the building ran on generators 24/7/365 for several years before the grid caught up... Roscoe |
| Author: | mix4fix [ May 13th, 2020, 1:55 pm ] |
I wouldn't live there. Only one way out and gets crippled by any and every weather event. You are surrounded by water. What about the flooding? |
| Author: | ratbagp [ May 13th, 2020, 2:14 pm ] |
Flooding is not an issue, even with king tides and storm surges. The Susquehanna Flats between the peninsula and Havre de Grace absorb a tremendous amount of water. There is occasional flooding in North East after heavy rain but there is an alternate back route. Yes, occasionally we get isolated for days, but we are used to it and we all have stocks of food and water. The closest supermarket is 11 miles away in North East but when I was working I would just call home when I left work to see if we needed anything. It would take me roughly 30 minutes to drive to the local community college where I worked. During an idle moment while I was trundling along, I calculated that I had spent a year of my life on that road. The final five miles through the forest is a wonderful driving experience with multiple curves and hills. Of course, there are deer that leap out at you which can be unnerving. ray |
| Author: | Cogito [ May 13th, 2020, 6:40 pm ] |
Can you post pics of your beautiful neighborhood. |
| Author: | ratbagp [ May 13th, 2020, 7:04 pm ] |
Back in 2012 I did the walk from the north to south rim of the Grand Canyon. I took some photos of my three mile training walk around the community and down to the nearby lighthouse which will give you an idea. The roads have been paved in the meantime. http://ratbagp.blogspot.com/2012/05/grand-canyon-getting-ready.html If you have the time, continue on to the following blog entries for the walk itself which was a wonderful experience. If you have the time and the health, do it. Here is another blog of what it looks like behind my house. http://ratbagp.blogspot.com/2019/01/the-ninth-anniversary-of-my-retirement.html#comment-form My drive up the peninsula http://ratbagp.blogspot.com/2016/11/some-autumn-leaves.html A bald eagle makes an appearance. http://ratbagp.blogspot.com/2015/02/a-bald-eagle-makes-appearance.html ray |
| Author: | TubeDriver [ May 15th, 2020, 11:23 am ] |
Looks like a great place to be! Sunsets in your neighborhood must be something else. |
