| Old DAC versus built-in DAC http://dcaudiodiy.com/phpBB3/viewtopic.php?f=5&t=1479 |
Page 1 of 1 |
| Author: | mix4fix [ November 8th, 2019, 4:08 pm ] |
| Post subject: | Old DAC versus built-in DAC |
What's worse: an old DAC or a built in DAC in the average cheap DVD/CD player? Would that old DAC improve the player's sound? |
| Author: | Roscoe Primrose [ November 8th, 2019, 4:30 pm ] |
| Post subject: | Re: Old DAC versus built-in DAC |
You’d need to look at it on a case by case basis, but generally speaking a good old dac is probably better than a cheap new player... |
| Author: | mix4fix [ November 11th, 2019, 12:38 am ] |
It's that Pop Pulse that has the left channel issue when connected to optical. I hooked it to a old Sony DVD player and use it to listen to CDs. |
| Author: | mix4fix [ December 29th, 2019, 2:53 pm ] |
How about the built-in DAC on the average AV receiver? |
| Author: | TubeDriver [ December 29th, 2019, 3:55 pm ] |
I bet they measure quite well. mix4fix wrote: How about the built-in DAC on the average AV receiver?
| Author: | DaveR [ December 29th, 2019, 4:34 pm ] |
There's no one answer for every possible combination of products. Try it both ways and see which sounds better. It's fun! |
| Author: | Pelliott321 [ December 29th, 2019, 7:46 pm ] |
You could try just listening to music instead of monkeying around with junk equipment |
