| Plastic vs metal http://dcaudiodiy.com/phpBB3/viewtopic.php?f=5&t=1391 |
Page 1 of 1 |
| Author: | mix4fix [ June 6th, 2019, 2:57 pm ] |
| Post subject: | Plastic vs metal |
When our buddy Phil left for Florida, he gave me a homemade extension cord with a two outlet box. I use it occasionally. I damaged the outlet cover. It was plastic. I snatched one from the rental office. It is metal and bigger. Can't really use it because it over laps the plastic outlet box. So, I need a smaller plastic one. I was thinking. Does a metal cover vs plastic cover cause any kind of issue? |
| Author: | Roscoe Primrose [ June 6th, 2019, 3:26 pm ] |
| Post subject: | Re: Plastic vs metal |
mix4fix wrote: I damaged the outlet cover. It was plastic. You just mentioned the only issue... Roscoe |
| Author: | DaveR [ June 7th, 2019, 10:06 am ] |
They make plastic outlet covers that are pretty hard to break now. Either plastic or metal should overlap the edge of the box, it makes no difference which you use other than personal preference. |
| Author: | Stuart Polansky [ June 7th, 2019, 10:10 am ] |
Nylon is the key. At the local hardware store. |
| Author: | Pelliott321 [ June 7th, 2019, 10:13 am ] |
wood sounds better, maple over walnut not quite as good as carbon fiber |
| Author: | mix4fix [ June 7th, 2019, 3:07 pm ] |
I snagged a smaller plate and replaced it. |
| Author: | Stuart Polansky [ June 7th, 2019, 3:18 pm ] |
Roscoe, Check behind your fridge. You might need a new wallplate. |
| Author: | Roscoe Primrose [ June 8th, 2019, 1:34 pm ] |
Stuart Polansky wrote: Roscoe, Check behind your fridge. You might need a new wallplate. Is that why my fridge sounds a little veiled?
