When things go very bad
http://dcaudiodiy.com/phpBB3/viewtopic.php?f=5&t=1329
Page 1 of 2
Author:  Pelliott321 [ January 11th, 2019, 2:44 pm ]
Post subject:  When things go very bad
I took on a simple repair job for a client. I had to replace a USB connector on a USB receiver board on a music server.
I did not take pics of the mangled connector befor I removed it. but here is the completed repair.
Author:  Pelliott321 [ January 11th, 2019, 2:49 pm ]
Post subject:  Re: When things go very bad
when I was putting things together and connecting a 12 connector cable to the other side of the board the socket just popped off.
here is a close up
Author:  Pelliott321 [ January 11th, 2019, 2:53 pm ]
To me the pads look like cold solder joints.
Any way it was a pain getting this soldered back on
Instead of a 15 minute repair it was a 30 minute repair
Don't know if I will recover from this disaster today
Author:  SoundMods [ January 11th, 2019, 3:43 pm ]
here is a close up
HOLY CRAP!!!! Cold solder joints all! Murphy's Law at work.
Author:  tomp [ January 11th, 2019, 6:05 pm ]
If anyone ever needs to repair a board with surface mount components I have a hot air re-flow station you can use.
Author:  Pelliott321 [ January 11th, 2019, 10:34 pm ]
One does not need fancy equipment to do surface mount work
Author:  DaveR [ January 12th, 2019, 10:17 am ]
No, but it sure helps make it much easier.
Author:  tomp [ January 12th, 2019, 12:37 pm ]
Amen to that
Author:  Pelliott321 [ January 13th, 2019, 8:59 am ]
Part of my problem besides being _______(you an fill in the blank), is I really do not understand how the hot air thingy works or how to use one. I guess this is a good one for YouTube
Author:  SoundMods [ January 13th, 2019, 1:06 pm ]
I don't envy your task -- I am imitated by surface-mount anything. Specialized equipment is required.
During manufacture -- the parts are loaded using robotics and then flow-soldered as a unit. Apparently, the device you are working on would have benefited by a hole-through version of the multi-pin connector. Looking at your photos it seems to me that you can clean the pads and connections of solder -- set the connector in place and hand solder each pad individually with a solder pencil.
I would wear a jewelers bi-optic magnifier to get a close look while working. I believe you can pull it off. Once you solder tack the first pin -- that will anchor the connector which will enable working on the rest of them. I think if you try to re-flow them as a group you may still end up with cold joints that will not be reliable.
