| How are Victor turntables? http://dcaudiodiy.com/phpBB3/viewtopic.php?f=5&t=1289 |
Page 1 of 2 |
| Author: | mix4fix [ November 9th, 2018, 5:57 am ] |
| Post subject: | How are Victor turntables? |
Victor TT-71 with 5045 arm. |
| Author: | Pelliott321 [ November 9th, 2018, 8:34 am ] |
| Post subject: | Re: How are Victor turntables? |
Looks like a pretty good looking TT. The only real problem I see is there are no motor speed controls. No servo, not even a pitch control, so you are at the mercy of what ever speed it's set at. Also it looks like there were many different configs, different plinths etc. |
| Author: | Roscoe Primrose [ November 9th, 2018, 10:28 am ] |
From what I can find on-line, it is a servo-controlled design. It looks like any speed adjustments are internal, so it's a set it once and forget it.... Roscoe |
| Author: | Pelliott321 [ November 9th, 2018, 12:22 pm ] |
Victor does make servo controlled tables but I read the "71" is not |
| Author: | Roscoe Primrose [ November 9th, 2018, 12:26 pm ] |
The info here: http://www.thevintageknob.org/jvc-TT-81.html says it is... Roscoe |
| Author: | Pelliott321 [ November 9th, 2018, 12:30 pm ] |
"The TT-71 is an 81 without +/- servo, no pitch control, an even simplified stroboscope circuit and a solenoid-activated braking pad." It dose say there is a servo in the positive line |
| Author: | Pelliott321 [ November 9th, 2018, 12:34 pm ] |
early 80's that depend on a lot of electronics. How would you ever fix it? I like the looks. Put it in a heavy plinth and take your chances |
| Author: | Roscoe Primrose [ November 9th, 2018, 12:42 pm ] |
Pelliott321 wrote: early 80's that depend on a lot of electronics. How would you ever fix it? I like the looks. Put it in a heavy plinth and take your chances It's all discreet electronics, so IF you could find a schematic, you can probably find suitable replacement parts for everything in there. Kinda like my Denon DP-3000 Roscoe |
| Author: | mix4fix [ November 9th, 2018, 1:47 pm ] |
Somebody's pawning one off on Audio Circle for $200 shipped. I would probably want it checked/fixed like my amp is going to be now. Recent discussion has people offering tables here so I am window shopping. Tube has one for like $500? |
| Author: | Pelliott321 [ November 9th, 2018, 3:20 pm ] |
could not find a 71 on AC there was a 31, not pictures I would be cautious get the owner to send pictures |
