Isolation transformers http://dcaudiodiy.com/phpBB3/viewtopic.php?f=5&t=1216 |
Page 6 of 10 |
Author: | Pelliott321 [ July 8th, 2018, 4:51 pm ] | ||
Post subject: | Re: Isolation transformers | ||
I always float the ground first to see how it sounds. I know this is dangerous, but I am still here, even though with what's going on in the world I have to ask why? or is it worth it? anyway here is my Felix
Author: | SoundMods [ July 8th, 2018, 5:04 pm ] |
Pelliott321 wrote: I use the Felix on my analog devices and have a special filter for digital devices that blocs trash both ways. I plan to use the iso tranny I got and build another box that will incorporate both filters, two zone as it were one for digital and another for analog not putting anything on power amps. Im no wondering about the Quad 67 power supplies, what to put on them Hey Paul! When my Acoustats were in my system I added Corcom filters and I'll be damn if the sound wasn't improved. As it turns out the bias can be corrupted in a way to mess with the sound reproducition even though its just a charge on the diaphragm. |
Author: | Pelliott321 [ July 8th, 2018, 5:17 pm ] |
I still do not know what Corcom filters are |
Author: | tomp [ July 8th, 2018, 5:46 pm ] |
Look at my post on page 3. Corcom is a brand name of some high quality filters. If you magnify the photo I provided you can see the schematic of how it is laid out, all inside a sealed and grounded metal case. There are lots of other high quality noise filters in both stand alone and component designs that should be used in an enclosure. |
Author: | Pelliott321 [ July 8th, 2018, 6:25 pm ] |
Does not look much different from the Felix The iso xformers I bought has a very similar filter on the primary side |
Author: | tomp [ July 8th, 2018, 9:12 pm ] |
Lots of different ways to do it. The advantage of the packaged units is the designs are thoroughly tested and they only have to be plugged in. Different strokes for different folks. |
Author: | Pelliott321 [ August 6th, 2018, 2:55 pm ] |
I decided to take the plunge and give an iso xformer a try. I bought a 10a unit off ebay but it needed work to bring it up to minimum clean audio requirements. Attachment: iso1.jpg [ 131.16 KiB | Viewed 8763 times ] The unit has a nice big Toroid.com xformer, but it has a switch for 110/220 VAC and a real crappy (although it had a CorCom filter in it) mains switch with fuses Attachment: iso4.jpg [ 143.33 KiB | Viewed 8762 times ] Also it uses IEC jack for out put, so I am replacing them (with a little metal work with PS Hospital grade 20 amp duplex. Not sure what "Hospital Grade" means) Attachment: iso2.jpg [ 139.55 KiB | Viewed 8763 times ] |
Author: | Pelliott321 [ August 6th, 2018, 2:59 pm ] |
What I do not understand is the grounding scheme Attachment: iso3.jpg [ 98.19 KiB | Viewed 8762 times ] what you see here is on the right post are ground wires for the input mains and the output sockets what was on the left post was the ground(or shield) from the xformer. Why did the manufacturer do this? What was gained? |
Author: | Pelliott321 [ August 6th, 2018, 7:19 pm ] |
There is absolutely no measurable (to 3 decibel points) resistance between them I would understand if there was a 1 to 10 ohm resistor between them, so its a big question. |
Page 6 of 10 | All times are UTC - 5 hours [ DST ] |
