Here are a couple photos of card wound resistors I found at the hamfest on Sunday FYI...about all I could find to buy!
The two on the nude phenolic formers look to be WE or Daven, And I found a weird rubber coated mica card resistor marked Tektronix. This construction is naturally low impedance. Zero impedance is basically impossible. Stability and low noise are the reasons for these rather than low inductance
per se. There are some with special winding geometries for even lower inductance, but these kinds of resistors are usually in DC or low frequency circuits where the small inductance values have little effect.
Radio textbooks will say that power transfer is maximized and reflections minimized when a line is terminated in its
characteristic impedance. So in David's example of a 75 ohm line, if you terminate it with 75 ohms to ground, it acts like it is infinitely long, so no reflections occur.
In audio, this approach of matching the line will result in input impedance values that might be tough to drive, unless you have one of Walt's 6 ohm Zout Levinsons (without the bobbin mod.)
I don't know how to make a cable with 10k-100kohm characteristic impedance. Twisted pair is ~100 ohms. Easier to go lower than higher with any cable one would want to use in hifi.
However characteristic impedance of a cable is not the same notion as a
transmission line. In a transmission line, the instantaneous values of voltage and current vary along the line and this phenomenon has pronounced effects when the line is at least significant fraction of a wavelength.
Think of a
transmission line speaker. The length of the passage is a specified fraction of a wavelength and the phase rotation of this defined length is used for impedance transformation. 1/4 wave being the commonest implementation. a quarter wave transformer transforms an open circuit into a dead short. Complete inversion. Xl becomes equal and opposite Xc and so on.
In my current speaker project, I measured a 425hz suckout with my phone. lo and behold, the front to back dimension is a half wave at that frequency! Aha! ReflectionZzzz!! I put in that piece of rock wool board I was looking for to break up that path inside the cab and no more suckout. This is a reflection, coming back 180 degrees out of phase to the cone, but I wouldn't call this a
transmission line design, using acoustic path length as a transformer, its just a box that had a destructive reflection.
I'd be careful about using any reactive components to terminate lines because while they will work at one frequency, they may PEAK the reflection at another frequency. Audio is very wide bandwidth phenomenon, covering many octaves. You can't cover that range with a tuned circuit. For the same reason, transmsission line principles seem to have limited relevance in audio interconnections.
Anyway, with speakers the back EMF and the speaker acting as a microphone sending signals back to the mothership would probably far outweigh reflections due to impedance mismatch at the speaker terminals.
