It is currently November 13th, 2026, 5:00 am
Post new topic Reply to topic  [ 63 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7
PostPosted: January 28th, 2018, 5:40 pm
Cool video. Really shows what is going on. Lots of schmutz on the record also.
PostPosted: January 28th, 2018, 5:51 pm
Nice job on that brass weight!
Shoot for 9-12hz resonance, lower is better than higher but the ears must provide the final judgement. Wild oscillations at the resonant freq are not good.
Presumably splitting the difference to ~10hz would give moderate oscillations and hopefully more open sound. At least you will know that the arm/cart combo is happy.
With a heavier arm, that weight would probably be perfect but you have to adjust for the conditions at hand.
PostPosted: January 29th, 2018, 6:28 am
Thanks guys
It took way too long to make that brass weight. Screws for cartridge had to be counter sunk with a flat bottom. Screw hole for arm mount had to be threaded.at m3.50. This I all way smaller than I am use to and my shop is set up for wood working not this small stuff.
Need to listen more and tweak arm adjustments before I make a 2gr lighter mount, but I suspect that is where it will end up
