It is currently September 22nd, 2026, 1:56 pm
PostPosted: June 6th, 2021, 2:32 am
What is the size of the screw used to mount 3.5 hard drives?
I am getting conflicting information online.
PostPosted: July 1st, 2021, 10:32 am
6-32 3/16 to 1/4 inch long
PostPosted: July 1st, 2021, 11:16 am
Anybody who has worked inside of computers, installing motherboard, hard drives, optical drives, case screws, etc. have been frustrated with the standards mix for screw-types used to secure the hardware.
Basically almost all computer screws are either SAE 6-32 or Metric M3
For instance, 3-1/2" hard drives use SAE 6-32 threads as Paul stated. However 2-1/2" harddrives or SSDs and optical drives use M3 threads.
Motherboards use either M3 or 6-32 screws to fasten the board into the standoffs, which themselves are typically provided with 6-32 threads to mount to the case. I have standoffs that are M3 female and 6/32 male, talk about a mix.
Computer cases typically use 6-32 threading.
I usually have a container with a mix of M3 and 6-32 screws that I have collected over the years, and just select what fits when I am installing computer hardware. An M3 screw just slips into a 6-32 hole, and a 6-32 screw will not fit in a M3 hole without cutting new threads and jamming (not a good thing). Never use brute force!
PostPosted: July 1st, 2021, 4:43 pm
Now you tell me ;)
Users browsing this forum: Bing [Bot] and 11 guests
