It is currently November 13th, 2026, 4:52 am
PostPosted: December 14th, 2018, 5:40 pm
I've come across several London multi-disc CDs where there is a thin pinkish foam pad on top of the CD. This foam pad deteriorates and sticks to the disc! If you have any of these I recommend you run, not walk, to your CD collection and check to see if any of your discs are infected. If you have this problem, I recommend you VERY gently try to pull or wipe the foam off while still in the case, vacuum the case with a brush attachment but still be very gentle. The information on the CD is on the top where the foam is stuck, it's easy to damage the data beyond repair. I suggest you rip it immediatly, I don't know if the foam that is still attached to the disc will continue to eat the disc. Spritzing some water on the disc may also help, but be gentle. Key word, gentle.
This is a public service announcement.
PostPosted: December 14th, 2018, 6:04 pm
Thanks for the warning
PostPosted: December 15th, 2018, 11:36 am
DaveR wrote:
I've come across several London multi-disc CDs where there is a thin pinkish foam pad on top of the CD. This foam pad deteriorates and sticks to the disc! If you have any of these I recommend you run, not walk, to your CD collection and check to see if any of your discs are infected. If you have this problem, I recommend you VERY gently try to pull or wipe the foam off while still in the case, vacuum the case with a brush attachment but still be very gentle. The information on the CD is on the top where the foam is stuck, it's easy to damage the data beyond repair. I suggest you rip it immediately, I don't know if the foam that is still attached to the disc will continue to eat the disc. Spritzing some water on the disc may also help, but be gentle. Key word, gentle.
Most people do not know that the data molded into the disc is directly under the label on the back side of the disc. The laser reads through the polycarbonate substrate to the backside of the disc. Although the back side is layered with a fairly thick coating containing the label information it can be damaged to where it will render the disc unusable.
This is a public service announcement -- part 2
