| DIY XLR Interconnects http://dcaudiodiy.com/phpBB3/viewtopic.php?f=4&t=920 |
Page 1 of 1 |
| Author: | chris1973 [ November 10th, 2017, 7:06 pm ] |
| Post subject: | DIY XLR Interconnects |
Hey all, I just recently bought a couple of Cardas XLR plugs to build some Balanced Interconnects. My plan was to buy the Lessloss Cmarc bulk triaxial cable: https://www.lessloss.com/cmarc-bulk-wir ... p-225.html But it appears its going to be a lot of work preparing the ends of the cable. You need a solder pot, some super glue, and a lot of patience to get the wires tinned and shrunk down to suitable size to fit on the XLR solder pins. I was just wondering, (for the people that believe that cables do make a difference Thanks, Chris |
| Author: | SoundMods [ November 10th, 2017, 7:36 pm ] |
| Post subject: | Re: DIY XLR Interconnects |
chris1973 wrote: Hey all, I just recently bought a couple of Cardas XLR plugs to build some Balanced Interconnects. My plan was to buy the Lessloss Cmarc bulk triaxial cable: https://www.lessloss.com/cmarc-bulk-wir ... p-225.html But it appears its going to be a lot of work preparing the ends of the cable. You need a solder pot, some super glue, and a lot of patience to get the wires tinned and shrunk down to suitable size to fit on the XLR solder pins. I was just wondering, (for the people that believe that cables do make a difference Thanks, Chris I've made XLRs out of Illinois Wire and W.L. Gore shot-gunned micro-wave cable. It is a royal pain-in-the-ass. I do have some nice Teflon TSP in stock that would be easier to work with. Stranded silver over copper with silver over copper shield and Teflon dielectric and jacket. It's a pretty blue color. |
| Author: | tomp [ November 10th, 2017, 8:16 pm ] |
My go to wire for interconnects is Belden 1800F. It works well at audio frequencies, has a 100 ohm impedance making it perfect for AES/EBU, is very flexible, has a nice matte finish, and has a French braid shield which is a joy to work with. If you want to try a few feet I can provide it. Here is the Belden data sheet. https://edesk.belden.com/products/techd ... /1800F.pdf Tom |
| Author: | chris1973 [ November 10th, 2017, 8:44 pm ] |
Hey Walt, I don't mind doing some homework and labor, but there needs to be some sort of technological gimmick to it. I started a couple years back with an 8 strand silver litz braid interconnect which served me pretty well for several years. It took advantage of the superior conductance of silver obviously, but supposedly the 8 strand litz increased the skin area, and also cancelled out noise. I finally replaced that with Alumilloy, which is a JPS labs patented alloy that somehow carries an audio signal with greater resolution than silver. It outperformed my silver litz by far! Alumiloy went head to head with Cardas when I made that decision, because somehow with Golden Ratio conductors, Cardas figured out how to make copper perform better than silver with an audio signal. Lessloss also has a gimmick, and like the others I think it is real too. CMARC mostly uses skin effect by breaking down the primary conductors into many tiny individual conductors, all isolated from each other with a lacquer coating (kind of like Cardas), and traveling in opposing spirals to cancel out noise. CMARC comes in bulk even though it's a lot of work to turn it into a finished cable. In order to get the other technologies I mentioned however, I had to buy finished cables. I'm trying to incorporate some ideas like these into a DIY format. I'm willing to do a little work. I'm just wondering if anybody is kicking around ideas like these too?? Thanks, Chris |
| Author: | SoundMods [ November 10th, 2017, 10:39 pm ] |
chris1973 wrote: Hey Walt, I don't mind doing some homework and labor, but there needs to be some sort of technological gimmick to it. I started a couple years back with an 8 strand silver litz braid interconnect which served me pretty well for several years. It took advantage of the superior conductance of silver obviously, but supposedly the 8 strand litz increased the skin area, and also cancelled out noise. I finally replaced that with Alumilloy, which is a JPS labs patented alloy that somehow carries an audio signal with greater resolution than silver. It outperformed my silver litz by far! Alumiloy went head to head with Cardas when I made that decision, because somehow with Golden Ratio conductors, Cardas figured out how to make copper perform better than silver with an audio signal. Lessloss also has a gimmick, and like the others I think it is real too. CMARC mostly uses skin effect by breaking down the primary conductors into many tiny individual conductors, all isolated from each other with a lacquer coating (kind of like Cardas), and traveling in opposing spirals to cancel out noise. CMARC comes in bulk even though it's a lot of work to turn it into a finished cable. In order to get the other technologies I mentioned however, I had to buy finished cables. I'm trying to incorporate some ideas like these into a DIY format. I'm willing to do a little work. I'm just wondering if anybody is kicking around ideas like these too?? Thanks, Chris My experience has shown that Cardas works as a "band-aid" -- Cardas does not stay out of way. I've had the best XLR experience with Audioquest W.E.L. signature interconnects with the 72-volt DC battery bias -- between my DAC and pre-amp. My AES/EBU connection between my transport and DAC is via Audioquest Coffee with the battery bias. They have blown away each every "store bought" and DIY cable I have. |
| Author: | DaveR [ November 11th, 2017, 7:00 am ] |
I've been using Audioquest S-5 SVideo cable for my interconnects for quite a while. So far, nothing I've compared them to has sounded as good. The cable has two solid core solid silver coax with three layers of shielding each. If you'd like to hear a single ended interconnect I'd be happy to loan you a pair. |
