It is currently November 22nd, 2026, 10:20 am
PostPosted: November 20th, 2023, 9:18 am
The room is rebuilt after the water problems are solved, time to go back to the AGN Line Array project.
This is the room before the damage and repairs with the Aegean Blue AGN Line Arrays. Will be moving them back to the listening room now that it is redone. Luckily the automotive paint protected the wood from the water and the baffles are ok.
The 6x12's made by Ruben in the picture, base cabinets were destroyed by the water, so getting cut a new set of modular 6x12 flat packs to build new servo sub arrays. First set of 6x12 flat packs are here with the second set in work. I have a plan for the remaining original sub modules. :)
Already have the DSP block diagram ready to test with the dspNexus 2x8 when the subs are ready.
