It is currently October 27th, 2026, 3:45 am
 Post subject: Ripole Subwoofer
PostPosted: August 24th, 2017, 3:17 pm
does anybody have any first hand knowledge in this design
http://jazzman-esl-page.blogspot.com/2011/01/ripole-subs-are-underway.html?m=1
 Post subject: Re: Ripole Subwoofer
PostPosted: August 24th, 2017, 4:03 pm
Looks like the Linkwitz Phoenix except the woofers aren't aligned front-to-back and wired out of phase. His comments about the compression in the space between the drivers being different than the Phoenix are just plain wrong, the Phoenix is push-push too.... Paul (Don Diego) is using a pair of the Phoenix subs that I built years ago with his Acoustat 2+2s.
PostPosted: August 24th, 2017, 5:06 pm
So his description may be wrong but do you think these will work
I also found this
http://www.peerless.de/index_hifi_en.htm?http://www.peerless.de/hifi/ripol_en.htm
which can be stacked
ripol_schema.gif [ 731 Bytes | Viewed 36284 times ]
PostPosted: August 24th, 2017, 5:21 pm
To me it looks valid and I find it interesting that the free air resonance is lowered. Of course as with all things audio you won't know until you build them.
PostPosted: August 24th, 2017, 5:24 pm
I got eight woofers salvaged from the Amazings to play with
PostPosted: August 24th, 2017, 5:31 pm
They're all just variations on SLOBs, they ought to work fine. It's really mostly a question of the size/shape that works for you.
PostPosted: August 24th, 2017, 5:35 pm
SLOB?
PostPosted: August 24th, 2017, 7:00 pm
SLOB?
Slot Loaded Open Baffle. There's a thread here: viewtopic.php?f=4&t=819 , and Nelson Pass has an article on passdiy. You've got some reading to do ;)
Users browsing this forum: No registered users and 213 guests
