| Chip-amp amplifier http://dcaudiodiy.com/phpBB3/viewtopic.php?f=4&t=690 |
Page 1 of 1 |
| Author: | mix4fix [ August 14th, 2016, 9:09 pm ] |
| Post subject: | Chip-amp amplifier |
http://www.parts-express.com/dayton-aud ... e--300-385 http://www.parts-express.com/pedocs/man ... manual.pdf ---------- brombo wrote: I make this when I though I was going to make a tri-amp system with horn mid-range and tweeters. It is two DTA-2 Class-T amplifier modules from Parts-Express with a packaged power supply. The DTA-2 modules are modified so you can set a pot and zero the DC offset. I though zero dc offset was needed if the amps were to directly drive horns. I hooked up and tested on of the modules into a dummy load and it worked fine.
