| Joe Roberts Coleman Coax cable (JRCs) http://dcaudiodiy.com/phpBB3/viewtopic.php?f=4&t=679 |
Page 1 of 6 |
| Author: | dberning [ July 25th, 2016, 8:47 pm ] |
| Post subject: | Re: Joe Roberts Coleman Coax cable (JRCs) |
I used the same RG type when I made the cables for my A-B-X box. Solid copper inner conductor with silver plating, and braided copper shield also silver plated. Just seemed like an ideal construction with out having any experience with it. I got my cable a year ago from Fairfield Microwave, and also picked up some of Joe's at the show. While the manufacturer is different, the construction is the same. David |
| Author: | TubeDriver [ July 26th, 2016, 8:13 am ] |
Do they sound the same? You might have to ABX your ABX box? dberning wrote: I used the same RG type when I made the cables for my A-B-X box. Solid copper inner conductor with silver plating, and braided copper shield also silver plated. Just seemed like an ideal construction with out having any experience with it. I got my cable a year ago from Fairfield Microwave, and also picked up some of Joe's at the show. While the manufacturer is different, the construction is the same.
David |
| Author: | Stuart Polansky [ July 26th, 2016, 8:22 am ] |
Thanks for the review Pete. Since my need is for XLR-RCA, I'll try out the parallel runs. Hoping that because my speakers (92dB/W/M) are way less efficient than yours, that the low-level dullness is not an issue. Hopefully the cables can be put together this week after another project for a friend. Hate to lose air/space/detail (that's a definite fail for me) , so fingers crossed. Stuart |
| Author: | J-ROB [ July 26th, 2016, 9:04 am ] |
Glad you're liking the 223. Sorry bud...Can't use my name unless I get 10% of the profits...all expenses are strictly on you, of course! I suggest "Hilton Audio OFC Transconnect"...OFC for "Oll-right! Free Cable!" You will note they sound a lot better after 10000 hours break in. Set an alarm for 9999.99 and be there for the transformation. The characterization is apt. SMOOOOVE. I picked this cable using a big horn system and those Altec/WE cones I like where this orientation works out. The HF is definitely non-emphasized but is there. Most of my setups only do 13k, as do my ears. Excessive zing is the cardinal sin of hifi in my mind, but obviously HF "detail" is a popular attribute in the marketplace. Watch the capacitance on long runs, particularly into hi Z inputs!! If this was $300 a foot Cardas, one would move the gear closer together, but free wire encourages long interconnects. Human nature. I think this stuff runs ~50pF/ft. Do the math. I agree with Dave that this stuff looks good on paper: silver plated copper inner, nice PE insulation--which I have found to sound great in interconnects, better than teflon, and dense double silver-plated copper shield. Quite a premium grade RG coax. To get anything better, you might have to spend some real money, up to several bucks a foot. I got more if anybody needs it. |
| Author: | TubeDriver [ July 26th, 2016, 3:24 pm ] |
Some good points to consider, Joe. In some ways, my setup is not ideal. I run an autoformer, non-active preamp to 10+ feet of interconnect to my amps. However, my DAC has a built-in volume control with a robust discrete output stage designed to directly drive amps, and my amps have a nice 100k ohm input impedance. But my guess is that with an active preamp and shorter interconnects (1-2m), the "dullness" and loss of soundstage and air at lower volumes might not be an issue? Then there is the whole break-in issue, I know that new stuff tends to sound different after our brains have adapted and also the item itself might undergo some change with use. I did not allow for break-in so additional time will be needed. All I can say is, it is better than the entry level Copper AudioNote interconnect I have and that is without even factoring in the price differential. "Hilton Audio OFC Transconnect"...OFC for "Oll-right! Free Cable!" is is. HAOFC! I certainly would not mind another couple feet to try out a 1.5' set for phono stage to preamp and perhaps TT to phono stage! Thanks. |
| Author: | David McGown [ July 26th, 2016, 3:34 pm ] |
50pF/foot is a little high for phono cable, unless you use a short length. I need to fire up my soldering iron and make up a pair to try against my Cardas (which need retermination). David |
| Author: | ratbagp [ July 26th, 2016, 3:43 pm ] |
Any recommendations for RCA plugs? What is the advantage of Tellurium? ray |
| Author: | Roscoe Primrose [ July 26th, 2016, 3:46 pm ] |
David McGown wrote: 50pF/foot is a little high for phono cable, unless you use a short length. Depends on how you define phono... Between a low output MC and a step-up/phono stage, the capacitance is pretty much a don't-care because the MC output Z is so low... For a high-output MM, you'll need to be careful, but if you can easily change the input capacitance of your phono stage, it shouldn't be a problem there either. Roscoe |
| Author: | TubeDriver [ July 26th, 2016, 4:01 pm ] |
I run about 1.5' from TT to phono pre and 2.5' from phono pre to Preamp so length is not an issue. Plus, like Roscoe stated my MC cartridge is not all that susceptible to capacitance issues. David McGown wrote: 50pF/foot is a little high for phono cable, unless you use a short length.
| Page 1 of 6 | All times are UTC - 5 hours [ DST ] |
