Input Tube Selection for Amplifier
http://dcaudiodiy.com/phpBB3/viewtopic.php?f=4&t=50
Page 1 of 3
Author:  High Transconductance [ June 4th, 2013, 9:52 am ]
Post subject:  Input Tube Selection for Amplifier
I'm beginning design work on a new power amplifier. Initially, I've decided to use two cascaded DC coupled long tailed pairs for the driver stage. These will AC couple to MOSFET source followers to then DC couple to G1 of a triode connected KT88 or G2 of a 26LW6 (two designs, AB2 and screen drive).
The second LTP will be a 6SN7, with about a 600V B+, 10M45S in the tail and ~ 33k-47k plate loads.
For the KT88, medium gain 1st stage will probably suffice, so a 6SN7 will be tried there. But for the screen drive, I'll need more gain, hence, my group question: what triode choices do you suggest to audition for the first tube, with high gain? I will consider pentodes, such as an EF86, but ONLY if a triode can't get the job done well.
I'm setting up a project platform, so I can audition several types, it will have one octal, one nine pin, one two-pair nine pin and one two pair seven pin selections.
So far, I'm considering 6SL7, 12AX7, 12AT7, 6AM4, 6GK5. Thoughts? Additions? I know the 6GK5 hasn't worked out well for Charlie, but that was a first stage phono application, and I don't know if that result has any bearing on a signal level at least 100x that of the phono stage.
Thanks!!
Author:  Roscoe Primrose [ June 4th, 2013, 10:20 am ]
Post subject:  Re: Input Tube Selection for Amplifier
It's about time you did one of your own :obscene-drinkingcheers:
Thanks!!
:character-oldtimer: That's probably a reasonable assumption. You might also look at the 5842, the 6J4/8532 (I have >150 8532s if you want to play) and even the 6DJ8/6922s. The 5687 might also be worth a look where lower gain is acceptable, but keep in mind that it has a different pin-out than the 12AX* series...
Author:  rock4016 [ June 4th, 2013, 10:22 am ]
The 5965 might be worth looking at too.
Author:  High Transconductance [ June 4th, 2013, 10:44 am ]
5842 might be too expensive for me. The high gm is attractive, but I've heard there are some long term reliability issues. Still....
The 6J4/8532 has very high Cg-p @ 4pF, otherwise looks great, worth a try. The 5965 has a bit less Cg-p @ 3pF, but that is still a very high number which makes me wonder is the tubes aren't better suited for grounded grid operation, otherwise facing a heck of a high frequency rolloff.
Thanks, these are worth looking into.
I'll have to borrow a quad of 6J4, uncle Roscoe!
Author:  High Transconductance [ June 4th, 2013, 10:48 am ]
True enough, the Citation II/Hedge has been around in some form or another since before I joined the club, I keep piddling and building for others.
BTW, how do I post pictures? I tried hosting at Photobucket, then inserting the link in Img brackets, but it didn't work.........
Author:  Roscoe Primrose [ June 4th, 2013, 10:56 am ]
I think photobucket has something that blocks remote linking to their pictures. You can always upload them as attachments, subject to the 2MB per attachment, and 3 attachment/message limits.
Author:  High Transconductance [ June 4th, 2013, 11:07 am ]
Okay, didn't see the button until now.
Let's see.....
Author:  High Transconductance [ June 4th, 2013, 11:24 am ]
The circuit will resemble this one designed by Tubelab and modified for Chrish (sp?) on diyaudio
Author:  FerdinandII [ June 4th, 2013, 11:32 am ]
How about a 6N7 in one of those diff amps? :idea:
It's already got the common cathode wired up internally, and u=40 might be useful on the high gain version.
It will do 6-7 mA in class A, and probably a lot more.......
Author:  High Transconductance [ June 4th, 2013, 12:20 pm ]
Interesting. Any idea where to find curves and Cg-p data? I only found a listing as a Class B amplifier. I may even have some. Did I mention I like octal? :D
