Okay: Hoots & Grins, here is what I was thinking about the pre-amp power supply:
File comment: Pre-Amp Power Concept
Run everything from a combination of solid-state Constant-Current Sources (CCSs) and cold-discharge voltage-regulator (VR) tubes. The tubes look cool, and are apparently quiet if driven by a CCS. The High-Voltage (HV) shunt regulator is an 0A3 in series with an 0D3 to regulator to 225V. The two first-stage regulators are a single 0D3 per channel. I'm undecided about the two CCSs.
My problem is I have no experience with VRs. I don't know if I should split up VRs for the later stages like I did for the first stage because of the current draw: If I run the VRs at about 20mA, I can probably loose up to two of the four modules (two second stages, two drivers) without overloading the 40mA VRs. That's not true in the first stage - if I loose a triode, the VR will overload with 55mA of current. I need enough voltage to strike the series VR string, but I'm worried about power dissipation of the HV CCS (maybe one of Charlie's C5Ss). If it drops 105V, it has to dissipate over 13W.
Just for information, here is a block diagram of my heater arrangement. No cascodes or wickedly-powered cathode followers so I don't have to worry about multiple heater supplies, though I should bias the whole thing up to +40V to turn off the heater-cathode diode. I ended up with an odd number of tubes, so instead of loading one side of a split 12.6V supply with the driver heater, I'll use a 12SN7 across both 6.3V supplies instead of a 6SN7 across one leg. Looks like I need an Amp of heater current - can't do a series string because of all the different currents.
File comment: Pre-Amp Heaters
More Comments?
