| Turntable 45RPM issue http://dcaudiodiy.com/phpBB3/viewtopic.php?f=4&t=2467 |
Page 1 of 1 |
| Author: | mix4fix [ June 1st, 2025, 1:50 pm ] |
| Post subject: | Turntable 45RPM issue |
Just an update on my office turntable. I noticed the 33/45 button was sticky when it was pushed. I use some cleaner and "Q-Tip on a stick" cleaning swab and I got it un-sticky. Seems to working OK. Bad part is it completely erased the writing around it (33/45, 12/7). |
| Author: | SoundMods [ June 1st, 2025, 2:20 pm ] |
| Post subject: | Re: Turntable 45RPM issue |
mix4fix wrote: Just an update on my office turntable. I noticed the 33/45 button was sticky when it was pushed. I use some cleaner and "Q-Tip on a stick" cleaning swab and I got it un-sticky. Seems to working OK. Bad part is it completely erased the writing around it (33/45, 12/7). Any acetone-based solvent and even some alcohol-based solvents will erase screen print. Water to clean and a thin oil application after could have saved the printing. DIY Lesson no. 12.3.
