Converting Magnepan MG10QR's to DSP crossover
http://dcaudiodiy.com/phpBB3/viewtopic.php?f=4&t=2243
Page 9 of 9
Author:  SoundMods [ November 5th, 2023, 1:15 pm ]
Post subject:  Re: Converting Magnepan MG10QR's to DSP crossover
Built a phono cartridge cable RCA to XLR interface box to drive the RIAA Phono capability in the dspNexus 2x8. It is a fully balanced phono interface to the coils. Setup with 47K Ohm resistance load and nominal capacitor for the Shure cartridge in the tonearm.
I put in a few different grounding modes, so testing it with the Oracle Delphi MKI and Linn Sondek LP12 should be interesting.
Welcome to the balanced-line phono playback club. And yes -- to the naysayers -- it definitely is an improvement over single-ended RCA connections.
Author:  HAL [ November 5th, 2023, 1:25 pm ]
Nice balanced phono interface box!
Looking forward to giving this a try.
Author:  SoundMods [ November 5th, 2023, 2:43 pm ]
Thank you! All compliments are appreciated. Before I went to the "Dark Side" and went to an optical cartridge I was using a moving-coil cartridge with a full complimentary phono stage. XLR in XLR out.
The playback was quite remarkable -- the DS Audio came along and the rest is history.
BTW -- balanced line is perfect for moving-coil cartridges -- moving magnet not so much.
Author:  HAL [ November 12th, 2023, 11:46 pm ]
Just finished packing after CAF.
Found the wiring problem in the phono interface box and without a soldering iron no easy way to fix it.
Great to see mix4fix and Roscoe stop by. Always good to catch-up when possible.
Page 9 of 9 All times are UTC - 5 hours [ DST ]
