Recently finished a complete rebuild of my nearly 20yr old PP 2A3 monoblocks. Fixing a few nagging problems with the original design, using a different driver topology, a modern and more robust power supply, and much nicer vintage potted power transformers (the old power transformers were cheap Allied by Hammond that buzzed and ran very hot). Still using a Hashimoto HW-60-5 output transformer. Basic topology is a modified Mullard 5-20 front end, only using 1/2 of a 6CG7 as the input, direct coupled to a 5687 LTP phase splitter that is choke loaded on each section (using the primaries of a Lundahl LL1692A), and a CCS in the tail, which is cap coupled to the 2A3 grids. The 5687 running at 15mA per section and around 180V across the winding has lots of voltage swing so should be nice and linear. I would have preferred to use interstage coupling, but the Lundahl rings like mad, and it complicates negative feedback and compensation (using around 6dB global NFB). So to keep the 10K squarewave response nice and clean, using cap coupling for now (that can always change with further experimentation in damping the secondary). I am using cathode bias for now...fixed bias is an option should I go with 300B power tubes
Oh, pictures..
| Attachments: |
