| New rack in the house http://dcaudiodiy.com/phpBB3/viewtopic.php?f=4&t=2052 |
Page 1 of 4 |
| Author: | Pelliott321 [ August 22nd, 2021, 10:15 am ] |
| Post subject: | New rack in the house |
I built this recently. Shelves (except for top which is solid walnut) are Richlite Supports are solid cherry I turned from a neighbor's tree that went down about four years ago Turning 20 spindles was tedious and very time-consuming. Ends were treaded with 3/8 by 16 tpi and then reinforces with CA glue and cut again. I used 3 inch pieces of 3/8 inch all-thread to hold it all together. Very stable. Attachment:
| Author: | Pelliott321 [ August 22nd, 2021, 10:35 am ] |
| Post subject: | Re: New rack in the house |
here is a pic of the spindles and rough wood being worked on Attachment: spindle_2_5in.jpg [ 94.05 KiB | Viewed 69809 times ] |
| Author: | tomp [ August 22nd, 2021, 12:00 pm ] |
Beautiful job Paul! |
| Author: | DaveR [ August 22nd, 2021, 12:05 pm ] |
Beautiful job indeed. |
| Author: | Pelliott321 [ August 22nd, 2021, 2:01 pm ] |
Thanks for the flashback, I spent many dollars at the Heathkit in SS |
| Author: | SoundMods [ August 22nd, 2021, 4:09 pm ] |
I've seen your cabinet making skills before -- no surprise here. NICE! Are you going to install casters to enable ease-of-access behind the rack when you wish to make system changes? |
| Author: | Pelliott321 [ August 22nd, 2021, 6:22 pm ] |
I have done extensive testing and have determined that casters sound terrible Actually I rounded the bottoms of the cherry feet and they glide very easily over the carpet |
| Author: | brombo [ August 22nd, 2021, 7:45 pm ] |
Is that an htpc on the first shelf? |
| Author: | Pelliott321 [ August 22nd, 2021, 9:15 pm ] |
That is an Innuous Zenith with a BorderPatrol DAC SE-1 on top |
| Page 1 of 4 | All times are UTC - 5 hours [ DST ] |
